Supra fan shroud on sc300?
Hey guys. Need to get a new fan shroud for my 1995 sc300 5 speed. I was wondering if the 93-98 supra shroud would fit? No junk yards around have one, and a shroud from the Lexus dealership is $250 (not including tax). A Supra shroud from a Toyota dealership is $115. Big difference. Any info would be greatly appreciated.
^^ This. If you're on an SC radiator the MKIV radiator won't fit it-- conversely if you replace your radiator with an MKIV spec then your SC300 shroud won't fit. You can modify your SC shroud, however, but the best option is to keep the correct shroud with its corresponding radiator.
In case you are going to use an MKIV shroud with an MKIV radiator, there is a small bracket for the MKIV radiator that you will need to have it bolt up on the upper right. It's $6 and five bolts are used in all. Then you will need to notch your battery tray with a Dremel cutting wheel and 90-degree angle extension. After that, the MKIV shroud is a perfect fit. The lower half-moon section that encloses the lower area of the engine fan is the same part between the SC300 and MKIV. You put that part on last, before replacing your lower chassis diffuser.
Deegee
SC- 1st Gen (1992-2000)
10-31-15 02:40 PM
xspsi6
Performance & Maintenance
03-17-13 03:06 PM
