Lug nuts loose!!!
Think the manual says 76lbs. I'm always between 80-85 and definitely check once in a while. Spacers can get tricky of course since you can't visually review the stud bolts at all times. I remember when I use to run spacers and I took a wheel off and a damn spacer nut rattled right out. It kind of freaked me out and I made the decision to run wheels with a wider offset.
