Can I get rid of this poke
From what I've seen, wobble bolts are for cars that use bolts to attach the wheel to the rotor. Not our cars which have bolts drilled in and lugs. So that's outta the question. Go with a redrill or wide body fenders.
I'd get the wheels redrilled, they should fit nice without the 1" adapater.
Lower and camber, roll and a lil pull. I had more poke than that and mine fit just fine...now! lol. But thats permanent mods, so if you plan on getting a new set they are going to have to be fairly aggressive. If your not wanting that then just get new wheels now.
So I'm guessing these wobble nuts are the wrong application for a sc and I will look into re-drilling. Around what cost should I be looking for, for someone to do it right
Is that what all that **** was from on the back lol. Dude just get some wheels that fit your car. Looks wack with some skinn wheels on the back just to have them. Sell them and get same ones that are made for your car.
wobble (also called variation) lugs or bolts (both exist) will only work from 5x112/5x114.3, 5x110/5x112, etc. the max variation is 2.5mm, they cant move 6mm. redrill them and be happy.
Lol this was a case of friends thinking it would be funny to plastidip the back of my car before I knew it could peel off
