new case for 97 remote
With a little bit of modification, the remote case for a camry works with the 97 remote.
97 remote on left, generic camry case on the right. I did the first one with a dorman brand case, it worked a bit better than this one.
Dorman on the left.
The inside of the camry case is different, so the inside plastic ridges need to be trimmed, also some small pieces of plastic need to be glued in as spacers so the buttons don't activate if the case is squeezed.
Cut the ridges and also the rubber gasket. Glue two pieces back onto the back of the panic button to make the rubber thicker.
Here is where I glued the spacer, you'll need two of them. One on the top and the other in the middle. The Dorman case also needed two little spacers.
The finished remotes. Dorman on right, generic on left.
Dorman on the left.
danegerous
SC- 1st Gen (1992-2000)
10-28-14 04:27 PM
Din
11-21-09 08:02 PM
morisato
03-08-03 08:40 PM
