SC- 1st Gen (1992-2000)
Got into a little accident
Old 05-13-13 | 09:38 AM
OmgSc400's Avatar
OmgSc400
Default Got into a little accident
Hey Guys !
Heres the story , It was early in the morning and i was suppose to meet up with a friend at a gas station . While i was turning out of the gas station, I guess I turned too fast ( I know my mistake) sorta hit /drove over the cement. I thought everything was fine , until I got home and notice that my undercover was bent , and while i was checking if there was any damages i found a loose hose( it is located right under the battery tray). I was wondering what hose would it be ?
I was suspecting steering , cause the steering was sort of lose . Or would it be a radiator hose?
Old 05-13-13 | 10:08 AM
Ali SC3's Avatar
Ali SC3
CL Folding 100000
If it was a steering hose it would be shooting power steering all over the place for a few minutes and then no power steering, so its probably not that.
there is a hose that is attached to the battery tray that is supposed to just be hanging, in case water is sitting in the battery tray it drains to the ground, it is not supossed to be attached to anything.
It sounds like everything is alright, maybe post a picture.
loose steering is probably steering rack bushings, I have replaced them on every SC I have owned.
Old 05-13-13 | 10:37 AM
SC400slide's Avatar
SC400slide
In Recovery Mode
CL Folding 25,000
Ali is right, there is a loose hose that comes out the bottom of the battery tray just in case the battery leaks all of it's contents into the engine bay.
Old 05-17-13 | 06:51 PM
OmgSc400's Avatar
OmgSc400
Is there anything else i should check for? the undercarriage is bent to the point it stick downward =S. And the front bumper seems a bit off ( but not noticeable) . I'll try to take a picture as soon as possible
Old 05-17-13 | 07:38 PM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
When we receive a picture, we can give you a better assumption and cost of the damage if needed.
Old 05-19-13 | 11:51 AM
OmgSc400's Avatar
OmgSc400
here are some pictures , I hope someone can give me so me advice =S
Old 05-19-13 | 12:12 PM
Ali SC3's Avatar
Ali SC3
CL Folding 100000
nothing is damaged except for the scratches on the bumper and a few underbody plastic pieces are were ripped out of the holes and crushed a little bit, you could probably take them off and straighten em out some and put them back on with some bigger washers, or just get some replacement ones froma junkyard, or just take them off and call it a day.
Old 05-19-13 | 12:59 PM
Luxor's Avatar
Luxor
You sure bent the hell out of the tow hook though.
Old 05-19-13 | 02:04 PM
OmgSc400's Avatar
OmgSc400
indeed I have =( , I wonder if i can hammer it back to shape..
Old 05-19-13 | 04:19 PM
Ali SC3's Avatar
Ali SC3
CL Folding 100000
didn't even notice that guy, I would try hammering it back.
Old 05-20-13 | 08:59 AM
OmgSc400's Avatar
OmgSc400
Thanks guys! I'll post up some pictures once I have time to fix it .
Old 05-20-13 | 10:27 AM
bam11's Avatar
bam11
Glad you did not need a tow )
bloodredSC
Performance & Maintenance
03-19-09 10:17 AM
indelible
12
05-06-04 02:43 PM
