DC 12V for Reverse Camera?
Did you test to see if the camera is is powering on and sending a video signal like I suggested? I would try and power the camera from another source.
When you put it in reverse did the deck switch inputs? Should have. If the camera wasn't working then there would have just been a black screen.
You should just pay a pro to do it for you.
The deck never switched inputs. I've read the pioneer manual three times now trying to configure it. There's two video inputs, I tried both, tried grounding the camera in multiple places, tried the DC12v in multiple places. The only thing I can think of is the camera is either doa or the wires it comes with are messed up. I've read the amazon reviews, and apparently there are two versions of this camera. I got the original(old) version. The new version comes with an additional wire splitting from the Video cable that can be spliced into the head units reverse signal wire... Either way I bought a wire from radio shack to do the deed and still nothing. I appreciate the help though.
Yea I tried that, no signal. Deck never switched inputs either. No black screen, nothing. Deck works fine, had it installed by a pro after Amazon sent me the wrong wiring harness...
Keeper of the light
RX350LB
05-05-19 08:45 AM
corkycal
14
12-02-07 07:35 AM
