Wish the rear lips were deeper...but I wonder if 265 or 275 tires can be pulled off in the rear without looking like a "Camber Ship". If you're rolled and pulled, but still rubbing in the rear I can only imagine the rub with wider tires. Car looks good though.
thats with a 1 inch spacer, if i remove it a 265 wont be too hard
yep, a 19x11 +25 fit pretty easily under my wheel well, actually kind of sunk, so i threw my spare 1" spacers to make it more hella flush lol
Lol that's interesting that a 11 width was sunk in at +25mm. I had 18x10.5 +25 and they poked out almost an inch. Was it due to your previous wheels that you had on that they were sunk in?
yea i know its kind of weird, but i guess ive pulled and rolled my fenders so much that it was an easy fitment,
next wheel mod will be the 19x11s in the front with the wide fronts and some real 19x12s miesters in the rear,
im debating on order some 19x11 +0 all around and a vertex ridge kit rep for my track car. 19x11 should fit in the front no problem correct? my fronts are already tubbed and harness is relocated. and will be gettign +50mm front/rear fenders. i know ill need a spacer for the rear.
yea thatll be fine maybe you can get a 305 back there
Pretty sure a couple posts back shows the front with TT brakes installed, although its hard to see my laptop screen at the o'hare, so damn bright in here.
