SC- 1st Gen (1992-2000)
Just curious... Were the SC and Supra built on the same frame?
Old 01-04-03, 12:23 AM
Bentley1
Bentley1's Avatar
Default Just curious... Were the SC and Supra built on the same frame?
Since I bought my SC, I have noticed that it looks very similar to a Supra. They look to be very close in both size, shape, lines. etc. Were they both built on the same frame? What other similarities do they share?
I've been a long time fan of the Supra. It's cool to drive a vehicle that is very similar, and in some regards BETTER than a Supra.
Check out the pic of the SC I found in the picture gallery, along with a pic of a '93 Supra I found.
Attached Thumbnails Just curious... Were the SC and Supra built on the same frame?-sup-and-sc.gif
Old 01-04-03, 12:38 AM
T0ked
T0ked's Avatar
Basically the same frame. From what i remember, the SC is built on an elongated Supra frame (or the other way around, Supra on a shortened SC frame, same difference) which is why some of the parts are interchangeable. This is especially true of the SC300 which has the same 2JZ-GE engine as the non-turbo Supra minus different pistons and rods. Some have dropped in the 2JZ-GTE from the turbo supra into the SC.
Lexgendboi
Lexgendboi's Avatar
I believe the SC300 has the same powertrain as the supra nonturbo. That is how people can turbocharge their SC300 or even complete swap of the turbo 2jz-gte. IMO, the SC300's inner strutures is very much to identical to the supra. SC400 however is a little different due to the V8. I think to have an SC3 turbo is great, it both got the luxury and power. If not, i rather go with the supra turbo.
Old 01-04-03, 01:48 AM
lexcoupe
lexcoupe's Avatar
The supra shares the same suspension parts too.
Kevin
Old 01-04-03, 02:34 AM
Miles B
Hyundai Driver
Miles B's Avatar
Do SC300s have leather and tv? Over here we get:
Soarer 2.5GT-T: no leather no tv 1JZGTE
Soarer 3.0GT: no leather no tv 2JZGE
Soarer 4.0GT: no leather no tv 1UZFE
Soarer 4.0GTL: leather, tv optional 1UZFE
Old 01-04-03, 03:39 AM
T0ked
T0ked's Avatar
We got 2 trims, SC300 (2JZ-GE) and SC400 (1UZ-FE). Leather was optional on 300, standard on 400. TV not an option on either one. Towards the end, I think both models had same list of equipment, only difference being the engine. The 300 was offered with manual until 97.
Old 01-05-03, 03:31 AM
Toan Nguyen
Toan Nguyen's Avatar
Default umm....
Leather was optional on 2.5GTL...
GT Limited/Luxury with the 2.5L Twin Turbo 1JZ-GTE.
Old 05-09-17, 10:39 PM
Glenn8888
Glenn8888's Avatar
Default Is300
What about the IS300? Is it on the same or similar chassis to the Supra?
Old 05-09-17, 10:42 PM
Luxor
Luxor's Avatar
This thread is 14 years old lol
Old 05-09-17, 10:45 PM
BigManne
BigManne's Avatar
Can't say they didn't search though lol
Old 05-09-17, 11:33 PM
KahnBB6
KahnBB6's Avatar
Received 1,243 Likes on 866 Posts
No, the IS300 (Altezza in Japan) was a totally new frame design first released in 1998 (Japan). It was designed primarily around the lighter weight 2.0L 3S-GE high revving four cylinder engine but was designed for the 2JZ-GE for export markets. The other engine it was designed for is the 2.0L 1G-FE inline-six non-turbo. The chassis used key Lexus GS (Toyota Aristo) suspension components:
https://en.wikipedia.org/wiki/Nobuaki_Katayama
In the Japanese market it was more or less acknowledged that the Altezza was intended as a semi-practical sporty car intended for modification, what with the availability of a high revving four cylinder mated to a 6-speed manual. In the U.S. it was marketed as a compact luxury sport sedan even though we did get a 2JZ-GE and a manual and optional LSD... which for Lexus was huge.
Nonetheless, the first generation 2001-2005 (USA) IS300 is an overbuilt car much in the same way the MKIV/Soarer/SC is... but it's not the same chassis, no. Most of the performance Toyotas from that time were still over-engineered.
If you're wondering if chassis components are shared between the IS 1st gen and our cars? No, totally different chassis. Only the GS of the same era shares a few components. The engine and general transmission layout/mounting however... yes, all that is shared with the exception of the engine computers and harness wiring being different.
Old 05-13-17, 05:41 AM
jimmymac30
jimmymac30's Avatar
not anymore!!! Smh lol
Old 05-13-17, 05:47 AM
plex
1UZFE/2JZGTE
plex's Avatar
I've owned both (SC and Supra) SC was around 550rwhp and Supra is around 800rwhp max. While they are very similar the Supra just feels more dialed in and a driver's car compared to SC. But for fairness my Supra started out as a 5spd NA Hardtop SE basically the base model, cloth non powered seats. It obviously weighs less than SC. I have traction controlled dialed in through the Infinity ECU with R888's all around so the car is very solid even with most of the original bushings which I plan to replace next winter. I loved and miss the SC but the Supra is a totally different driving experience IMO even at 550rwhp like the SC had.
Old 05-14-17, 02:55 PM
97-SC300
97-SC300's Avatar
You're right.... the SC drives like a luxury car (if it's a well maintained and not a beat to sht example).
Supra drives MUCH more rough. More vibration, more noise, way more rattles. Less interior room by far.
Since neither car is great on an actual track anyway and more of a straight line kind of vehicle, especially at those power levels, I'll take an SC all day. But maybe I am partial to a luxury ride as I prefer cars like a GS, LS, LX over stuff like Supra/EVO/Elipse etc.
Basically, to me the Supra felt like what the SC would be if you stripped it and angled the dash towards the driver. Take away some of the sound insulation, use cheaper materials and take away the comfortable seats. Which makes complete sense since the Supra was marketed as a sports car and the Lexus marketed as a luxury GT. It comes down to your preference at the end.
My SC is already extremely loud some times. Loud motor, loud exhaust, loud fuel pumps, etc. I can't imagine having it be even louder, that's why I insulated the entire cabin as much as I knew how. Definitely not a road trip car or a daily driver at this point.
myLEXsc400 (05-15-17)
Old 05-16-17, 11:05 AM
LexIS007
LexIS007's Avatar
Couldn't have said it better...
Quick Reply: Just curious... Were the SC and Supra built on the same frame?
