dash removal help
I Have been following the diy for this and I can't seem to figure what to do after dropping the steering column. I removed the 2 nuts inside the cluster section and harness is no longer connected. Then the guide says to do work behind the dash? There must be more because this thing is not easily seperating. Anybody got any ideads? Will take pics soon if i need to.
So I have removed the nuts and bolts as the service manual says and should be able to remove the pad at this point but its not coming out easily. I don't see anything that I might have missed that may be keeping this thing in? Im afraid if I use force im going to break something.
I believe I have all of the wires removed from the dash. I manged to pry up on it and it seems looser but still not quite there. I realized that the service manual section I posted does not have the passenger airbag. Is this because its meant for an older SC? I don't know if there are any changes when removing a 97 dash.
Finally figured this out. Ashamed to say that the answer was right in front of my face but w/e. Turns out if you are trying to remove the later years dashboards with a passenger airbag, you have to remove 3 gold bolts that hold the airbag in!
well on driver side there is air vent simple but that stopps it 1 screw, on passenger side same thing, alos on the a piller ull notice a tab from dash going up along the a pillar fram a plastic fastner hold it to a piller reomove those, un plug the smal plugs for senseors on dash both passenger and river side, alos what i did was i cut w a razer blade every where is ay the PINK tape that holds harness to dash, once u do that u can move it free BUT right in the moddel the harness it screw to the bottom opf the dash u have to remove the passnger side up enought tio stick a phillips n there and remove 2 screws 1 on each side or harness plugs plate, oce u do that it should come out those r the little secrets ive learned i take them out all the time cause i part no rebuildable sc's out so i can do it reaLL EASY , I WILL SAT REMOVE THE STEERING WHEEL OR IF U CAN POWER THE CAR LEAVE STEERING COLUN DOWN!!! so when u try to remove it dsnt get in ur wat that much cause ull still b able to get it but some times u brake the big tabs that stick dwn and then sucks cause u try to sel or reinstall it wount mnount right or let the ajacent panels installl nice and snug 9095226612 lmk if u need more help ill walk u threw it
