Sun Roof Issue
Sun Roof Issue
So when I bought my car beguining of last month, the sunroof worked flawlessly, then a couple of weeks ago I went to close it, and it wouldn't budge. I had to remove the dome light and manually close it.l the sunroof. Now if I try to open, it will slide back a couple of inches then stops and this loud grinding sound starts up. What I've been doing is using a flat head screw driver to help the motor thrn the screw. What should I do to fix this?
I'm not sure how the sunroof works in this car, but it sounds like the chain is off track..... Probably not an easy fix, I'd say open it all the way and if possible(I have no idea) try to connect the chain to a few teeth, then have another person try electronically closing it....
ur gona have to remove ur head loner and the auctuall sun roof asse3mbly everything so u cvan get a good look at it its most likey the sun roof is off lne or track sometime when that happends the track brake or the motor is going out . try the motor 1st if thjat dsnt fix it then ur sol and ull have to take it apart to see whats going on
