Other cars have it, but SC's don't....... and you want it
#78
Adding 2 more to my list:
Gas cap with a built in retaining cord (so it does not keep falling when filling up)
Center console without a radio power/volume switch (aftermarket radio installed and that switch is useless) will remove switch and wrap trim in future.
#81
Yeah my silver sc300 is sooo much better now that I don't have the factory seats in it, there's tons more headroom, plus sc300 seats are heavy as Hell I've swapped three sets of seats and it baffles me why these seats weigh so much.
#82
Auto close on the doors and pull down for the trunk if you gently latch it. Acura Legend coupes had the pull shut doors in them so it was not asking the impossible in this price class for the time.
One touch moonroof would have been good. The passenger window should also have had an express down feature like newer cars where it is "all auto" marked on the driver's master switch panel.
They should have put in an oil pressure and temp gauge.
The center arm rest should have been placed as to not have the driver put his elbow exactly on the top stitching to wear it away.
The glove box should have had a damper so the door does not crash down if you do not lower it all of the way manually.
The doors should have had a red safety light near the latch mechanism to alert other drivers of a parked car with an open door at night. The puddle light at the front of the door panel is not noticeable from the rear of the car.
The cig lighter and ashtray lights should have been switched by the door to shut off when the door is closed.
They should have put an additional 12 volt power port somewhere in the passenger footwell where it was not really seen to run a radar detector instead of having the ashtray open to do it.
The visor mirror lights should have not looked so economy car like with dollar store looking lens' in them. Use a lens similar to the dome light.
The trunk light also sucks in the SC. They should have had 2 lights that are not so cheap looking in there.
The nets on the seats should have been pockets instead.
The biggest blunder on the SC3 was running the air intake ducting over the exhaust manifold where it constantly cooks in the heat. They should have come up with something to keep the ducting on the cold side of the engine with a different intake manifold design similar to the turbo cars.
Stock electric fans would have been nice. The fan shroud would have been eliminated and opened up a lot of space. The mechanical fan also slightly eats up engine power.
Just use plain clamps on the heater valve and do not make it a PITA to deal with.
#83
#89
First time viewing this thread. Lots of good suggestions here.
Holy hell, I thought I was the only person who noticed that PITA!
I've often thought it could sort of be accomplished with a horseshoe shaped tank that uses more of the space near the shock towers, allowing for a small center pass-through as well as more clearance for subwoofer depth.
Re: adaptive headlights...
Really, that's what the cornering lights do? A year later and I still hadn't figured out their purpose! Has anyone tried wiring them up to the steering input to actually be adaptive and respond to x° off-center in either direction?
