sc400 thud noise only from turning right
I just acquire my self a 94 sc400 witj 187k miles. Equiped with nakamichi audio.. lol.. maintainent and evrything is good and engine is keep to date.. however. Whenever i turn right.. the noise "thud" happen. .. noteven full right. .. i did some searching . And some said it the stopper bolt cap. Bht mine didnt happen on full lock but half lock...... so yea. Turn right. About half lock. And it thud noise come on....
please shed some light.
I spoke eith the previous owner.. and whih turn out he a very honest guy.. anf he said sometkmr in pointnwhen he owned the car. He did replace the steering rack pinion which meant the whole thing . But i dont know if he rrplacr the bushing or not. So yea .. do u have a oicture of it.
http://www.flickr.com/photos/pjurisprudencia/9186299084/http://www.flickr.com/photos/pjurisprudencia/9186299084/ by http://www.flickr.com/people/pjurisprudencia/, on Flickr
http://www.flickr.com/photos/pjurisprudencia/9186296318/http://www.flickr.com/photos/pjurisprudencia/9186296318/ by http://www.flickr.com/people/pjurisprudencia/, on Flickr
Ok i.checked the bushing is good and new from what i seen.. the thud noise clunking is from.my bushing of my front lower control arm.. now.. should i buy the whole new arm...since the arm.been in use since 94 and now 2013 that 19 years . I serious dont want to replaxe the arm bushing and find out to know thr ball joint are bad.. u cant rrplace the ball joint form the control arm csuse is integrste into the arms.
control arm bushings are able to be bought from TM Engineering, I bought my Daizen bushings from them and i got it within a week. Check to make sure its your control arm bushing and not your ball joint, If it does happen to be your ball joint your arm will need replacing and then the new control arm bushings you just installed will go to waste unless were able to get em out without damaging it. I havent looked into the control arm bushings yet, mine are still good, my thud going forward and reverse is my drivers side ball joint so ill be paying a visit to my local wrecking yard soon.
To be honest i would hust want to get a whole new arm an then buy the bushing for it and install it at once.. cause i hate it .. well i jack the car up and wiggke the wheels and it seem like it not the ball joint because it doesnt have any play innit.. or i will buy anused arm and make sure checm the bakk joint
if you can afford new supra Lower control arms that's the way to go, they are also less expensive than the lexus ones and will improve the handling some and you don't have to worry about your balljoints later on. I replaced the control arm bushings it was a lot of work to get those bushings out, If I could go back in time I would have just got new arms and replaced them it would have literally taken half the time and a quarter the effort. those bushings are horrible it took 2 of us to get those things out with torches and various tools and then the cleaning, and burning rubber smells horrible.. all that and still an old balljoint.. but it did solve my problem and the balljoint still seems to be good but be prepared to get messy.
