Positive Wiring Options for Accessories
Looking for some insight on how you guys wire in aftermarket accessories like:
- Apexi SAFC
- Boost Controller
- Wideband
- Lighting
I'm aware of the cigarette lighter as an ignition based positive wire to tap into but I know it can't be good to try to splice all the accessories into that.
Would it be best to bring in a separate wire from the battery and trigger it with a relay off the cigarette lighter? What are some other safe tap in wires for wiring in accessories?
- Apexi SAFC
- Boost Controller
- Wideband
- Lighting
1JZ Single SC400
I used a power source that was triggered on by the key in the driver side kick panel. I also wired in a seperate fuse to protect the even further.
You can use a 30 amp relay for a safer way of doing it. Thats up to you. Alot have also used the lighter as well. To be the most safe, I say use a seperate relay and trigger it on by a switch in the kick panel.
Apexi SAFC -should go the pin on the ecu it says you to use in the write-ups, because you dont wan't the accessory fuse going and then your car will stall right away because of no maf or map sensor.
all the other stuff I usually run off the cigarette line because that is the accessory line and is designed to handle a fair amount of amps, and the wideband and the boost controller don't use much electricity at all and work well on that line since they aren't as needed as the safc but the accessory line is pretty reliable unless you drop a penny in your lighter socket!! whoops.
So it would come down to the lighting and how much you intend to plug into the cigarette lighter. If you use a few led's that wouldn't be a big deal, but I am not sure how much lighting you are talking about.. lol. If the lighting is substantial then you are right about the relay you should run a relay just for the lights. I would not put lights and anything else important on the same line, because it will only be as good as the weakest link when they all share the same fuse or relay, and lights have issues from time to time.
I had a buddy good with wiring install this for me. http://www.supraforums.com/forum/sho...iteup-included
I have no intentions of anything extravagant for lighting, but I know I will want to run a car charger for my iphone in the cigarette lighter. I figured with everything wired in there, plus trying to charge my phone it may draw to many amps and pop the fuse.
Thanks for the suggestions guys!
