Help water in trunk
HOWEVER! The fact that it is draining into the spare tire well suggests to me that it is the sunroof tubes that are clogged. Wherever this tube winds up, will get wet if misplaced though! If draining into the spare tire well, it's likely clogged. If you are running a stock Nakamichi amp, handle this immediately as the water will destroy it.
Well upon expecting the drain hoses I found the one on the driver side was just laying there. It was still in the hole but not secured in any way. The hose was cut at an angle on the bottom. So I put it back in the hole dryed the trunk out cause there happened to be water by the drain on the driver side. Put some silicone around it hopefully that holds it and doesn't let it leak. I poured water on the sunroof and it drained out the tube. The headliner was not wet at all. So I will keep and eye on it and see what happens. I will report back in a few weeks and let y'all know. Anyone have a DIY on removing the headliner? I don't want to break the headliner. And do I have to remove c-pillars?
There is one other possible scenario. I thought my sunroof drain tubes were clogged as well but they were simply a misplaced and draining into the trunk instead of through the drain hole. My thread for that issue is HERE. Check my photo and quickly eliminate this as your issue by simply opening your trunk.
Do you have a wing on the trunk?
I have an aftermarket wing on mines since I bought my Lexi.
I had tons of water under the amp. My sunroof drain tube for some reason, some how got pulled out from the hole so all the water ended up pooling in that spot which gave me amp shortages.
However, my floor would also be moist in the center. At first I thought it was the sunroof tube but since I fix that, still got some water in the center of the trunk. Gasket is fine, etc.
So the wing required holes to be drilled. Holes that require some sort of rubber or foam gasket to keep water out. I'm am thinking none was used. I have yet to seal this possible leak off, but it is the better reasoning to me.
As for the driver side, I noticed some water traveling down from my antenna...
Well it's gonna rain the next couple days so I will know what's going on then. There use to be an aftermarket wing but it got broke off before I got the car. I got the holes plugged with those push plugs from the auto store and then some silicone around them. I got another trunk lid with a spoiler on It that I want to put on so if I continue to get water I will try that lid and if that don't fix it I will just pull the headliner to make sure the tubes are on securely.
Now when I poured water on the sunroof and the water drained I never had the headliner get wet.
thanks Teal SC400, I looked around the truck lid seal and noticed alot of leafs and stuff so i cleaned that all out and wiped the seals and everything so we will see what happens.
thanks everyone for their help I will keep yall updated. All of your guys responses is the reason i enjoy being apart of the lexus community.
There are many reasons why we get water in our trunks. Like people said above. Seals on trunk to seal the lid, the sun roof drains, and antenna gaskets. If I didn't use my son roof I would just take it out and have metal added on the roof. But I sometimes use it so I can't delete it.
E0FLK0PTR
06-22-21 12:15 AM
topgun129
01-24-10 07:38 PM
happy_es3
07-31-08 04:52 PM
