Want to thank you all for your help.
Just a thanks, for all the posts on helping me get my 95 sc400 running. I bought the sc about 7 months ago. Needed some work. First it was key, struts, tires and ran great for 5 weeks. Then just died. Turned over but no fire. I bought a lot of parts I didn't need trying to fix the problem. It had an after market security system. Took that out and grounded the green wire from fuse box. Still would not start. Disconnected the battery and went to work for the week. I finally had time to hook up the battery and it started right up. It had been a couple of months since I could drive the car. Shut it off and on a few times to makes sure I wasn't dreaming. It drove great!!!! So thank you all.
Now the bad news. drove my car for 2 days, about 100 miles. It started and ran great. I was at home talking to the wife when clouds were lurking. Went to close the windows and sunroof. Tried to start it and now it is doing the same thing as before. Turns over but no fire. I checked to make sure the ground was still in place, yeap. So I want to thank you all for your info, by the looks of it I will be searching some more. I get no codes. Thinking it is a wire issue just frustrated.
We're all here to help man! Heres the number one guide to fix SC4s. Found out my fix twice on there.
Good luck. https://www.clublexus.com/forums/sho...d.php?t=551125
13lind
Performance & Maintenance
01-09-14 11:36 AM
e-man
01-19-10 01:53 PM
