Climate Control Question
I need to remove my Climate Control unit and send it back to Lextech because almost all the bulbs plus the LCD have gone out. It was just done late last year.
Anyway if I remove the unit can I still use the car while it's out without throwing any codes or lighting up the CEL?
Keeper of the light
Make sure to tell the tech your car has issue with voltage spikes. Losing one over a year due to issues with the led might be foreseeable, but losing a few means your car is spiking the led's.
O. L. T. can you elaborate on the voltage spikes? What causes this and what is the solution. Could this also be the problem with my bright white LCD which is now light gray?
