Gated shifter trim question
Hey guys I've been searching around on here for a little while now, but I'm running into a bit of confusion. I'm looking for an ashtray, cup holder, and gated shifter surround with wood trim. I can't figure out what year came like this that still retains the heated seats and TRAC switch. Can anyone help me out?
98+ models that have the gated shifter do not have a TRAC button. They only have the Pwr/Econ switch and heated seats (if the car came with the heated seat option, mine didnt
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
If you're thinking about doing the shifter conversion, you should be able to do a few simple splices and have it working properly, as per the DIY floating around here somewhere. It looks pretty simple.
yea everyone has these problems because no one takes the time to show others how its really done.
Few scattered threads with no clear answers, the usual story.
Ive wanted the gated shifter for a long time, had the opportunity to buy many , but still don't have any definite answers on what to do with the overdrive.
The overdrive needs to be wired into the 4th gear people say, which is available on 'some' gated shifters, others say it can be wired in without the 4th gear, so who the hell knows.
As for the trac button you just need to dremel out a new hole in the wood trim, and it stays the same.
Gated shifter install is really easy. If someone really needs it I have wiring diagram to install a 99-2000 SC300 gated shifter into a 97 SC300. Mine is all plug in play as I was fortunate enough to get the connectors for the 97 already installed on my gated shifter. Splicing the wiring is a breeze. Here is the pic of when I got my gated shifter that already had the main harness plug and the overdrive plug already spliced together. Top pic is the ECT switch that still has the 99-2000 plug on it but you only have to splice three wires, it took me all of two minutes to make it work.
Mark, it actually was a little dirty in that pic.
Shane
Shane
I wasn't actually looking to do the gated shifter mod itself. I was more or less after the wood trim panels for the ash tray and surround, but again I don't want to damage a factory part to install something that wasn't an option. I'm pretty meticulous when it comes to that sort of thing. I don't mind my current stock set up at all. I'm just pulling inspiration from SC430 and my lighting mods (When I actually do them) from LF-A
