Oem Keyless Help!!!
Where in GA are you? I hooked up the lock/unlock and trunk pop wires at the stock alarm module plus the 12 volt + and the ground. Works great, the factory alarm still works as it should. All you are doing is replacing the oem keyless system. Check out 12volt.com they have the wires color codes and location for the SC.
Ali,- thanks for that info... is it posible that If I could just add the missing / needed wire for the trunk?? might mess around with this before I buy the aftermarket unit!!!
thanks everyone!! your help gotten me a step forward.!!!
Kosoku4lfe
01-10-08 05:45 PM
