Fabulous Profound Super Low Disk clearance
Hey guys, I have the chance to get my hands on some fabulous profound wheels, 18x9.5 +8 and 18x10.5 +8. The wheels are super low disk all around. Will these clear the stock sc400 brake calipers, or is a spacer needed? I know lower disk wheels need them with the bbk setup, but was unsure with the stock brakes. I have browsed the wheel/fitment guide, but just need a more specific answer if possible. Any help would be greatly appreciated as I do not want to let this opportunity slip by. Thanks for reading!
Ok thanks! My fenders are already rolled and pulled, just not sure if I will be able to run a spacer. Any additional input from others is appreciated!
welp since its already been established that they should clear brakes, i would just like to add in this will fit great in the rear, but yes the fronts might have some slight poke, rears will be great, you'll probably want to run a 235/40 in the rear and 215/40 in the front! well thats what i would run,
what size tires do YOU plan to run?
this is @iheartmysc's on 19x9.5 +7 and 19x10.5 +0 leon hardiritt bugel's 235/35/19 and 245/40/19
his front looks like it has 25mm origin front fenders.
![](http://i772.photobucket.com/albums/yy3/iheartmysc/SC300/L1000892.jpg)
Mojo95
SC- 1st Gen (1992-2000)
17
07-27-08 10:40 PM
