Two 8 second Lexus SC300's right in my back yard
#34
Super Moderator
Now I wonder what can we use on that firewall to be able to slide in the harness but at the same time prevent heat from going into the cabin ? I was thinking the original rubber accordion can't be used since it will melt because of the heat. On that area where they drilled the hole, looking at my empty engine bay , there is actually a 3" inch diameter mark there with a threaded hole at the center .
#36
they sell all kinds and diameters of grommets online. I would just get one for the holesaw size you will use.
the harness should be able to survive the heat right there on the intake side, only thing I can think of that gets really hot is egr and egr cooler on the back of the block if you have those but on JDM motors its blocked off.
I have heard of people placing the ecu in different places and would totally be worth it if the body plugs would reach there but somehow I am thinking they won't go that far.
