Oddball part query.
I had to take my driver's side door panel off because my power window stopped working. U'm hoping to get a new lift motor that will fix that issue. However, in the course of having the panel off, the blue plastic wiring connector that connects to the mirror controller on the panel got caught as I was closing the door and is now smashed into pieces. Does anyone have any ideas where I migjt locare one. I'm trying junkyards but have had no luck so far. Autozone, etc. are no help. I may have to try the local dealer but I was hosed on some replacement dash bulbs so I'm hoping to find other options if possible. I've tried Ebay too but it's hard to figure out what to put in the search engine to get that part to show and haven't had any luck there either.
you could actually get that plug from alot of different cars depends on how many wires. if its 4 wires, get them to cut a similar 4 wire plug from any lexyus or toyota and splice away. another option would be to get a new plugs, pin and crimp the wires and insert into new plug. GM weatherpacks are pretty cool i use them alot. I REALLY like the Deutsch sealed ones Harley uses but then you'd still have to hunt down the window motor..
Thanks for the replies. I was finally able to find and cut a harness plug that fits perfectly from an old Toyota Corolla at a "U Wrench It" type place. Tried five different junk yards until I found it!
DeanWeen
Performance & Maintenance
12-16-18 01:42 AM
jalperson
SC- 1st Gen (1992-2000)
12-06-02 03:46 PM
