1GS totaled, picked up 95 SC400.
As title says my 1993 GS300 was totaled on the 30th of August, and this week I picked up a 1995 SC400 with 201,000 miles for $1,800. $200 less than what I paid for my GS. Gotta love full coverage insurance! Midnight Indigo Pearl.
So far i've replaced the rotors and pads, next I plan on tackling that noisy power steering pump when the engine is cold. If anyone knows of common issues with the 400, let me know so I can try to tackle them before I work on cosmetics.
What I've found so far is rusted tailight harness where the bulb plugs into the harness, the driver side window doesn't go down, but the motor works, noisy power steering pump as I mentioned before, kind of metallic noise coming from the transmission kind of area I think.
welcome and congrats,
noisy Ps on my car means im low on fluid, check if your ps is leaking, and your window regulator clip broke, you'll need a new regulator. and what do you mean metallic noise? I get noises from that area because my tranny and motor mount were shot.
The PS is only noisy when the vehicle is cold, once it gets warm it stops making the sound. I filled up the reservoir yesterday because it was low, but still makes the noise when cold. I have not noticed any leaks yet.
To start I would remove the reservoir and thoroughly clean it with degreaser. There's a screen in the reservoir that gets clogged up over time and messes up the flow of the power steering system. There's also a solenoid filter that gets gunked up underneath the car but I would just start with the reservoir and see if that stops the whining then check for leaks. If you don't spot any leaks flush system with Toyota TIV ATF. It's what is recommended and when I bought mine it was only $4.25 a quart at a local Toyota dealer. Also if it's leaking from the pump fix it asap as it will take your alternator out which is directly below. Good Luck!
It's some sort of sensor screen filter underneath the car connected to the rack near the passenger side. I read you must drop the rack a little to get to it that's why I would start with cleaning the screen in the reservoir. Although this thread covers a range of power steering areas it helped me when my pump was whining. I ended up just thoroughly flushing the system with TIV and cleaning the reservoir filter so I got out pretty easy. Good Luck
Power steering whine Club Lexus thread link - https://www.clublexus.com/forums/per...e-whining.html
Small update for where I am currently sitting. Progress with her is very slow, bankroll is almost non-existent.
Anyways here is what I've started doing.
Both upper door garnish trims were cracked right down the middle and superglued by the PO of the car. So I picked up a pair from a member here on CL.
Here you can see I also replaced the driver side A-pillar since the old one was torn at the handle and constantly falling down. Has some glue like residue on it due to a previous owner, I've used goo gone on it with no luck, any ideas?
Also replaced the shifter trim with another I bought off a member on CL.
to
It's night and day!
I have a set of Tanabe DF210s left over from when my 1GS was totaled, holding on to them until I can get some 1GS shocks.
Don't mind the air mattress.
My old GS.
The last I saw of her.
I've learned my lesson to grab EVERYTHING I can off the car if it looks to be totaled. 2 week prior to the crash I spent 200 on JDM vent visors and also lost my entire stereo system.
So far I LOVE the SC. My favorite car to date. I cannot wait to be able to invest more time and money into her.
to
It's night and day!
My old GS.
Today I replaced my front rotors and pads, new alternator and powersteering hoses as well as a new battery. She feels like she has SO much more get up and go. Makes me wonder if my failing alternator was affecting her performance. She feels like a champion now.
I replaced my brake light switch as it was out, but my auto shifter is still stuck in park unless I do the bypass. Any ideas? Going to take apart the console tomorrow to have a look around.
