Fragola 8000 Fuel Line
Fixing to pull the trigger on new fuel system for my car. Been reading everything there is and talking to some guys here on the forum (thanks Jerry). I know what I want to do as far as injectors, pump and APR. My last decision is fuel lines. I've been reading about the Fragola 8000 fuel lines that are rated at 250 psi and E85 compatible. I can't find one negative thing said about it. It uses push in connectors which are a lot easier than anything out there too. Anybody using this fuel line??
Thanks,
Shane
Thanks,
Shane
Sweet, that sounds like alot easier than messing with the regular AN fittings. Only place you need braided steel is where it may rub, but if you run the lines correctly it shouldn't matter.
I've used the nylon braided with regular AN fittings way less of a PITA than the braided steel.
