SC- 1st Gen (1992-2000)
How do you tighten the seat nets?
Old 07-08-03, 08:01 PM
Bladez42598
Bladez42598's Avatar
I'm having the nets and the trim piece removed and having the plastic back custom painted to match the outside paint of the car. I think it will compliment my custom two tone interior nicely
Old 07-21-03, 04:24 PM
Hi-psi
Hi-psi's Avatar
Ok fellas,
Was going to take care of this little job on my SC this afternoon, but ran into a problem.
I got the back of the seat off fine, but I did not have screws holding the net trim ring to the seat back, rather these little metal clips. I tried to get one of the clips off, but feared breaking off the plastic post so I stopped. My car is a 1995. Any ideas on why I have these rather than screws? Any reccomendations on how to remove them?
Old 07-21-03, 04:44 PM
FaceUT
FaceUT's Avatar
I simply grabbed both sides with my needle nose pliers and pulled straight up. If they were down to where I couldn't get a grip I pryed them up a little with a small flathead screwdriver. I found that pushing them back on with a small socket and a nut driver worked pretty well.
FaceUT
93 SC400
92 LS400
Old 07-21-03, 06:03 PM
Hi-psi
Hi-psi's Avatar
Thanks,....I'll have to try that approach tomorrow.
Old 07-21-03, 07:25 PM
c_irie
c_irie's Avatar
yup that's what I did also and you only have to remove one from the top corner enought to pry the "U" shaped piece up get the knot out -shorten it cut it and tie another knot ...a 10 min job
Old 07-22-03, 09:37 AM
Ryan
Ryan's Avatar
That's right guys. Sorry I said screws before, I forgot it was those things. I just used a flathead screwdriver and poped them off. I pushed them back down with the screwdriver as well. This is all pretty easy to do.
Good Luck!
Ryan
Old 07-22-03, 09:49 AM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
yep, just pressure tabs. they press on and pry off
Ryan and MW, you both did a great thing here, many thanks.
Old 07-26-03, 09:54 AM
nextlevelcoupe
nextlevelcoupe's Avatar
invaluable info...............thanx!!
Old 07-27-03, 01:30 PM
Hi-psi
Hi-psi's Avatar
The needle nose plier approach worked well for getting them off, and the use of a nutdriver to press them back on was a great tip.
My girl ain't loose anymore,...err,....I mean she's really tight now,...err,.... you know what I mean.
Old 07-27-03, 09:16 PM
Aznteazer
Aznteazer's Avatar
so many things to do on my car this summer.
maybe this thread will be another sticky
Old 07-28-03, 09:20 AM
buuzy
buuzy's Avatar
Yep, this was the quickest and best improvement (AND FREE!!) that I did to my car. Now, I just need to fix all those burned out bulbs in my cluster.
Old 05-25-05, 08:00 PM
DavE713
DavE713's Avatar
just adding lil from you guys...since i took some pics of it..... the arrow show your where to push and pull make sure you push till it unclips then you pull it down
Old 05-26-05, 12:30 PM
mikeloc24
mikeloc24's Avatar
Nice pic man, give us some more info on what you did
Old 06-22-05, 07:53 PM
pilip99
pilip99's Avatar
getting started on this diy fix right now, glad to have found this thread, thanks ryan
Old 06-24-05, 02:41 PM
pilip99
pilip99's Avatar
finished up this diy job in about 15 mins, the screws were kinda tight to take out, anyways here are some pics, bump for a good thread ...
jus need to take out the extra tag end then it's fine
Quick Reply: How do you tighten the seat nets?
