How do the seat memory functions work?
On the drivers side door, there is a seat 1 button, a seat 2 button, and I believe a "set" button. How do I go about setting them up? I've read that the car needs to be in park to have it save the settings, but I can't seem to figure it out.
Thanks
Thanks
Get your seat, mirrors and steering wheel exactly how you want it and then hold down the one of the memory buttons until you hear a beep. You have just set one of the buttons.
The way I do it is, set everything mirrors, seat, stearing... then you have to have the car in the 'on' position and the car in park, then hold down 'set' and the 1st or 2nd memory position till you hear a beep sound. Then if you want to adjust back, you just have to make sure you are in park and 'on'.
Also, make sure that your foot is off the brake pedal. I was so used to just having my foot there when in park, and then couldn't figure out why it wouldn't move back when I hit the memory...then I took my foot off the pedal, and she worked just fine
Thanks guys. I've got it all working now.
The set button needs to be pressed and held, and then (while holding set) the seat 1 button needs to be pressed until a beep is heard. Repeat process for seat 2 button. Car must also be in the "on" position.
What a great feature!
Kdmc1LS460 (06-19-24)
