1jz swap wiring questions
So I'm putting a 1jz with an auto harness and ecu into my factory 5 speed and I was wondering what I should do with the extra transmission plugs. I also read that bridging pin 2 and 3 on the nss switch bypasses the switch and connecting 4 and 9 on the same plug to the 5 spd reverse light connector will get you reverse lights( correct me if I'm wrong). But is there a way to wire the nss switch to the clutch switch, has anyone had any success doing that? Oh and for some reason I can't find the power steering plug on my 1j harness.
