92sc300 5sp ~240km might have unreported damage, should i walk away?
hello
Don't think i have ever posted so here goes
I just saw an 1992 sc300 5sp at a used car lot available for 4k+tax. sc300 are rare around here, and have never seen a 5sp sc300 in two years looking,and maybe max 2 sc300 on craiglist in the area. I've only seen the car in the dark but two panels have a gap. Carfax shown is clean but i don't put alot of faith in that.
So the question is given the rarity of these cars possibly a reasonable price and likely unreported damage. Should i spend the 200 to take it to my mechanic to find out more or should i walk away?
If the cars were easy to find I would walk away without a second thought.
Details
US import from Colorado, been in Canada since 05
~240km
black on beige
cosmetic seemed ok, inside and out (1/4 inch puncture on driver seat, and back has a seam going at the top of about 6 inches), minimal cracking in leather. Paint looked fine (but it was dark, one chip on back bumper) no body damage that I saw.
The big issue is the that edge of the hood at the top corner on the drivers side doesn't line up with the quarter panel by about an 1/4 inch. Other side is perfect. hood didn't stay up on its own, might have just been pistons though and wasn't jerky when it slowly closed and rest of seams lined up. Other wise hood seems to open and close fine, but didn't really inspect much as it was dark and i didn't have a lot of time.
here is a picture of my car with the area highlighted (note this car doesn't have the issue)
Thanks,
Details
~240km
black on beige
Thanks,
usually if there is damage neither side lines up well. but yours is only on the one side.
maybe they shut the hood on a tool or something and bent the hood out of shape a little bit. ive done that before on my DD a Honda prelude, and it looks exactly like that.
Because the lights are all aftermarket, a front end collision is more likely to have happened at some point. Still, if the structure is straight and only minor panel damage occurred, from end impacts don't bother me so much. What I hate are rear quarter impacts. You can unbolt hoods, bumpers, and fenders, but quarter panel damage means welding and body filler are the only options. These cars are getting so old, finding one with zero history of damage can be very difficult!
I saw this car for sale on craigslist and I was also surprised at seeing a sc300 in Canada, not to mention a 5spd.
My advice would be to import something from the US. Seattle and especially Cali has so many more options for that same price range. Having said that I get all my SC's from the US and its not a complex/drawn-out process for me anymore, not sure whether you're willing to go through the same process.
open the hood and check the top of each fender for the vin number sticker. a replaced one will not have it unless done by toyota/lexus. also look for new paint on that side, whether its in the finish, or something just out of place on that side so check side to side like certain bolts they paint over from factory on the fender and they will age different, check both sides. also if the front end around the lights and everything is lining up well, it probably wasn't that bad and in that case I would also check behind the wheels on that side for a control arm that looks out of place or has junkyard writing on it. if everything looks original, it could be a simple panel alignment issue or just the fender took some damage and was replaced.
If it has been fixed right and was just mostly the fender its not a deal breaker for me, but I agree I would just buy a soarer if I was you =)
Thanks for your replies, took the plunge and bought it. Bone stock sc300 5sp. HUGE difference to driving my 92 sc400. ppl seem to like to see picks here, so will snap a couple tomorrow to post .
here are the CL pics, they conveniently dont show the damage (seats and panels)....might have a paint issue to took a risk there will keep you posted. otherwise appears well maintained.
Well did you get underneath and look at the frame? That would tell a lot more then anything else. From the looks of it, it's probably just a minor fender bender that got a new fender resprayed and bolted back on, and isn't lined up 100% correct. Also these cars are old, my 92, the door started sagging and rubbing the fender, so I had to get two guys to He-Man strength it back into position while one bolted it back down correctly. IMO if the frame isn't damaged and it drives smooth, go for it.
Tell the guy $3500 including tax right now and you'll take it. Bring up all your concerns and issues, and mention the head lights arent clear, the punctured leather seat, any scratches or scrapes, etc.... Look at recent Lexus Dealership history and see if any maintenance has been done, and if not tell them you did the history check and saw that it needs a full tune up, or timing belt, etc... There's always wiggle room for you. He's asking $4000...he'll take less.
How do you mean driving it is so different than your SC400?
There's a '95 5-speed SC300 on craigslist here (Denver) for $4500 obo, with 132K on the clock! It has a salvage title, and the owner says the interior is rough, but that sounds pretty tempting.
