SC- 1st Gen (1992-2000)
popularity of e85 in the states
Old 12-12-13 | 10:10 AM
99SC42's Avatar
99SC42
Why cast manifold? this spools so fast I don't get to enjoy the car off boost, It was great but i didn't like it because it was too violent.
No qs valve is needed and your rods will be on borrow time, donc soit modest and don't try to put reinvent the wheel.
Either turbos will make 600+
Old 12-12-13 | 10:35 AM
Ali SC3's Avatar
Ali SC3
CL Folding 100000
QS can hurt the top end power some. I would just go for a standard divided setup.
those cast manifolds are usually undivided and not sure how large you can go on the turbo with how they fit in there.
Old 12-12-13 | 01:15 PM
mecheng10's Avatar
mecheng10
I am going cast for the spool time and due to the fact that i know with a cast it will clear the dizzy (since im looking at a treadstone cast and its made for the is300 which only came with a dizzy)\
and what makes you say that the rods are on borrowed time?
Ive heard of 2jzges go over 800 hp. is it the rod that snaps? Or is it the rod bolts?
Old 12-12-13 | 01:17 PM
mecheng10's Avatar
mecheng10
im not shooting for a massive turbo for 1000hp or something like that. just a super fast streetable car (600-700 hp with good responsiveness). ive heard anything over 700hp isn't very street friendly. or it worse comes to worst, ill just cut a hole in the hood! hahahahaha don't think ive seen a sc with a turbo out the hood
and that's why I need a qsv. the cast is undivided and I want a .91 a/r twin scroll
and according to sound performances website, QSV wont hurt the top end power
Old 12-12-13 | 01:22 PM
99SC42's Avatar
99SC42
Ethanol makes more HP and TQ than c16/q16 etc..
TQ kills your rods, about 700ft lbs of tq you are on borrow time and its also about how it comes on in the lower rpm.
At those power levels the weakest link on the jz are the rods700tq+ and the main caps ~900-1000hp.
You will not have to worry about spool time with 10.1 CR and ethanol with 60-67mm turbos.
Old 12-12-13 | 02:23 PM
mecheng10's Avatar
mecheng10
well I did not know that. thanks for the heads up
and I wonder if cast vs tubular manifolds on e85 have been compared with the same turbos injectors and all that.
I wonder if there is still a spool difference.
and a good cast manifold is 400-500 while a quality tubular is 1500... hahaha
not trying to use any china made ebay special parts
Old 12-12-13 | 02:32 PM
Ali SC3's Avatar
Ali SC3
CL Folding 100000
yeah there is a difference between 800hp on pump and 800 hp on E85 and that is the massive amount of torque. I would take quicksc4's advice he has done it several times.
and the QS does hurt the top end power some, don't believe everything you read on the net. it is a trade off it helps the spool out if tuned correctly and it will shave some off the top end but most don't care. A proper divided stainless manifold with a divided turbo should spool fast enough anyways for the turbos you are using and you get unrestricted top end power.
The QS valve is actually for massive turbo's shooting for 1000hp, but your would have good spool already.
just get rid of the distributor or shorten it down and use coilpacks. do you really plan on running 600hp through 1 stock coil for a long time? you are going to loose power because of the gaps you will have to run. just get a regular manifold and spend the extra money on a ecu and coilpacks.
Old 12-12-13 | 02:50 PM
INTIMAZY's Avatar
INTIMAZY
Ehhhhhhh marketing is beautiful.
It probably isn't a significant drop but there is clearly an obstruction being placed in the exhaust stream. Not major by any means but it's there.
Old 12-12-13 | 02:56 PM
99SC42's Avatar
99SC42
The qsv has to be tune, You have to know where to close it and when to open or it will rob you some power..
One last time you do not need a QSV.
Old 12-12-13 | 07:33 PM
mecheng10's Avatar
mecheng10
alright. thanks for the help guys!
i want to go with the coils but im having a hrd time figuring all that stuff out. ill have to do some more research into it.
and i saw the soundperfomance supra with a cast manifold and a QSV with a precision 6766 or 6266 can remember and it had a gorgeous torque curve
thats what made me want to try a QSV
maybe ill look into an undivided turbo now
Old 12-12-13 | 08:27 PM
INTIMAZY's Avatar
INTIMAZY
Whoa whoa wait up. I think in general everyone says to go twin scroll turbo WITH a divided manifold. There was a thread back in the Evolution forums showing the benefit of open vs twin scroll.
Old 12-12-13 | 09:45 PM
BigSticks's Avatar
BigSticks
proefi flex fuel set up...
problem solved
Old 12-13-13 | 09:23 AM
mecheng10's Avatar
mecheng10
there is a difference though between the evo and the sc. aka number of cylinders. I don't necessarily think that something that applies to the evo also applies to the sc. from my understanding, which I could be wrong, smaller engines benefit more from twin scroll because they have less exhaust gas to spool the turbo. since the sc has more cylinders it would have more exhaust flow. so the twin scroll would not be as beneficial.
and its hard to find a good divided manifold for less than 1000 bucks. And I would prefer not to go china brand for quality purposes (aka don't want to have to spend 300 bucks on a manifold and another 500 bucks to get it to fit)
Old 12-13-13 | 10:19 AM
99SC42's Avatar
99SC42
Yes divided manifold makes a difference.. I was a non believer till i tried it , you do see a difference.
Old 12-13-13 | 11:57 AM
1CleanSC's Avatar
1CleanSC
So as I begin work on my sc300, I have been contemplating swapping the head gasket or not (to the tt hg) but as ive been doing more research, if you plan to run e85, the stock NA head gasket is better. im building my sc to have fun with (first built car!), take road trips in, that sort of thing. how popular is e85 in other parts of the country? I know here in ohio every krogers gas station has e85. so that means I have access to 3 e85 stations within 10 minutes of my house. but how is it in other parts of the country? is it hard to find? don't want to get stuck running low on gas with no e85 stations in sight! should I just bite the bullet and run the lower compression tt hg so I can still run high boost on pump? im gonna be running high boost a lot... never know when you are gonna roll up to that ricer civic! (that is a very bad problem here in ohio...)
Can't you tune the new Haltech 2000 for both pump and e85? Correct me if I'm wrong but that sounds like a hell of a compromise. In which case you should run the TT gasket just in case you want to run that high boost but only have pump gas available. Just putting my 2 cents in. I could be wrong.
