SC- 1st Gen (1992-2000)
Sc300 foglight issue
Old 12-30-13, 09:14 AM
Luxor
Luxor's Avatar
Since you have already replaced the relay and the fuse, now you need to look at the grounds and the switch. I have a strong feeling the switch is at fault.
You can bypass and check the switch by grounding the green wire/black stripe between the switch and the fog light relay. This is based of an electrical manual for a 1998, wire colors may have changed.
If the fog lights turn on from doing this, it means you have a bad ground at the left kick panel or the switch is not working.
Old 12-31-13, 08:25 AM
Nes
Nes's Avatar
How do i by pass? And this wire is located in the kicker panel area?
"You can bypass and check the switch by grounding the green wire/black stripe between the switch and the fog light relay"
Old 12-31-13, 08:26 AM
Nes
Nes's Avatar
How would i replace the switch at the stalk as you mentioned.
Old 12-31-13, 11:38 AM
Luxor
Luxor's Avatar
I've never done it before. The wire should be behind or near the relay in the kick panel area.
I also have never changed the stalk, I am sure there is a DIY somewhere on this forum.
Old 01-07-14, 08:16 AM
Nes
Nes's Avatar
I spoke to my mechanic and he is also agreeing with you that it seems like the fog switch on the lever/stem/stalk. My mechanic is going to look over everything from the relay, fuse, ground, switch and figure it out. Once he does I will post the outcome on here. THIS SITE ROCKS!!!!
P.S. I found my fog lights from two people on here...Yahoo.....i will post those picks once i have them installed. They have already been cleaned up...looks new....
Thanks to everyone...
Old 01-13-14, 12:09 PM
Nes
Nes's Avatar
Quick question about how much would it cost to replace the fog light switch on the stalk/lever?
Nes
sc300slam
04-02-10 05:26 AM
Royal769sr
14
03-28-10 05:31 PM
Mortal300
01-16-07 06:18 AM
dinh626
Lighting
04-16-04 01:34 AM
marcman18
03-17-02 11:37 AM
Quick Reply: Sc300 foglight issue
