SC- 1st Gen (1992-2000)
Door Wiring Issue
Old 12-18-13 | 11:17 AM
- V -'s Avatar
- V -
Default Door Wiring Issue
Hey guys,
So here is the problem. Whenever i use my window buttons on my door to roll down the windows, i hear a buzzing sound. Originally i thought it was the actual instrument that was broken but if i move around the wires coming out of the front of the door, it works again until i shut the door. I am assuming there is a wire that is broken contact somewhere or maybe a broken wire. I tried taking off the door panel but there is a metal cover that covers all the wires in the door.
My question is: How do I get to the wires so that i can fix it. I did all the research possible but couldn't find any threads that took the door apart past the door panel.
Any help would be appreciated. I'm hoping to take another crack at it this weekend.
Thanks
Old 12-18-13 | 12:06 PM
VEGAS2JSC's Avatar
VEGAS2JSC
check the ground wire in the rubber boot between the door and the chassis over time they tend to break or get weak and sometime have a contact and sometimes not. had this same exact thing happen a few months ago in my car.
this is the one im talking about
Old 12-18-13 | 12:42 PM
- V -'s Avatar
- V -
Yes that's where I thought the issue is too. But I didn't see any breaks in any of the wires so I figured its behind the door. I'll check again but is there a way to look at the wired beyond the section behind the gromet?
Old 12-18-13 | 01:15 PM
VEGAS2JSC's Avatar
VEGAS2JSC
were you able to check all of the wiring in the boot because i had to cut mine off to get the middle of it where the break in my ground was i just taped it back together.
beyond the gromet on the door side im not sure havent taken the doors apart on mine yet. the chassis side im sure you could gain access by removing the kick panel
Old 12-18-13 | 01:36 PM
Luxor's Avatar
Luxor
Big white wire with thin black stripe. That's the problem.
Old 12-18-13 | 01:41 PM
Luxor's Avatar
Luxor
I de-pinned all the connectors from the plugs to get the boot off then soldered the wire back together.
Old 12-18-13 | 01:48 PM
VEGAS2JSC's Avatar
VEGAS2JSC
^^proper way to do it haha it was raining when i had to fix mine so made it happen hahaha
Old 12-18-13 | 04:52 PM
- V -'s Avatar
- V -
Nice so I just unpin them and pull them from the front of the door? I'd prefer not to cut the boot
Old 12-19-13 | 10:06 AM
1JZPWRD's Avatar
1JZPWRD
1JZ Single SC400
You should be able to peel back the boot, how far, not sure.... Just try it and see..
isosunrise
03-05-14 04:06 PM
Dai Kaiju
03-24-12 07:35 PM
turtle54
08-04-11 08:42 AM
99navette
11-27-06 05:41 AM
ajs14
05-08-05 08:29 PM
