Little help?
Little help?
Hey guys, I'm relatively new around here. I have a problem, I recently had a bit of an accident in my 95 sc400. I was driving home one night and barely avoided having a tree go through my engine. Instead however, the tree took out the passanger side of the front of my car. Suffice it to say, I'm in desperate need of locating a new front bumper, fenders, lights ,fogs, sidemarkers. I'm thinking of locating a soarer front end swap. But figure I'd ask for advice, help, suggestions or any other info you guys could give. Pics below.
To get the full list of parts you will need, you have to take the thing apart.
Salim
Salim
*! UPDATE!* so after taking some more time to look at the lexus, I will need a new oil pan, since I'm pretty sure it got punctured. It has been leaking oil like mad from the underside. My question now is, can I buy an ls400 oil pan and just replace it. Since the ls 400 has the 1uzfe same as my sc. If that's the case then I can get it for cheap fix it in a couple hours and be good to go. After that all it seems I need is a pair of fenders, new headlights, fog lights, sidemarkers lights and a new front bumper. Otherwise, nothing else seems broken. Though it will need an alignment. Any help with this question would be appreciated, can I use the replacement oil pan for an ls400 on my sc400?
