SC- 1st Gen (1992-2000)
what is this?
Old 01-04-14, 06:36 AM
itrsalmaan
itrsalmaan's Avatar
Default what is this?
Hi,
i just opened my centre console today to install a audio player and found that there is a ECU (or kind of a computer) inside. what is that for?
Also how does AC work in SC400? as i dont have orignal ECU anymore (running haltech only) my AC stopped turning on
Old 01-04-14, 06:50 AM
SlowC400
SlowC400's Avatar
If its a wire harness connection then it's for the car phone, they did that so then it would be Easier to add that in the package at the dealership. If you can find one, it would be useless sense the technology is out of date, but it would still be cool to have.
Old 01-04-14, 07:48 AM
itrsalmaan
itrsalmaan's Avatar
if its useless then i will pull it out as i dont need it.
What about AC control?
Old 01-04-14, 08:04 AM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
On my AEM V2 and 1JZGTE I used pin A17 and A27 for the AC to work. If you need more info PM me. Although I am not a tuner or wiring guru as many others are on here.
Old 01-04-14, 08:05 AM
SC400slide
In Recovery Mode
SC400slide's Avatar
Could also be the alarm control module (something like that). In which case, you DONT wanna remove it.
Old 01-04-14, 08:36 AM
turbodremz
turbodremz's Avatar
If its the computer that was directly below the stock head unit, thats for your airbags. Look for yellow plugs or yellow wire loom.
Old 01-04-14, 10:47 AM
itrsalmaan
itrsalmaan's Avatar
its directly below my climate control unit (just a bit more inside)..... guess its airbag
Old 01-04-14, 12:19 PM
turbodremz
turbodremz's Avatar
Just to be sure so everyone can clarify, I would post up a picture of it to be sure.
Troymx576
Performance & Maintenance
12-31-17 06:43 AM
itrsalmaan
05-09-14 10:35 AM
wanganstyl
05-10-09 12:29 PM
Quick Reply: what is this?
