Who owns both *ZZ3* and JZA80 chassis?
Who here owns both a JZA80 Supra and SC/Soarer? How do the two compare in terms of handling / sharpness, etc?
EDIT: Prefer first hand experience
Yes just search there is plenty more threads comparing the two even Supra owners on here gave their opinion not sure what that thread is called.
Here is a thread I made about a Article comparing the 2
https://www.clublexus.com/forums/sc-...a-article.html
None of the mentioned threads actually get into the technical differences!
The JZA80 rear subframe uses different arm lengths (shorter) to give more dynamic camber change compared to the UZZ31.
https://www.clublexus.com/forums/per...-thread-4.html
This should give more rear grip under hard driving vs the soarer/SC that would have more grip under relaxed driving - in short Toyota/Lexus tuned the suspension of the car to suit the market it was targeted at.
I am actually swapping a JZA80 rear subframe into my Soarer....
I have not compared the JZA80 front subframe to the SC/Soarer but the front lower control arms are identical besides the SC/Soarer bushes are voided to be softer / compliant.
Typical soarer/SC bush
Which arms are actually shorter on Supras? The traction arm appears identical. So just the upper and lower arms themselves??
92blacktt
Performance & Maintenance
05-18-12 06:49 PM
