Trac lights come on after 5 minutes?
DA51, got your PM, sent you a reply.
The earlier post from Nextlevelcoupe may be a place to look - - if the high-pressure hose from the TRAC pump to the accumulator is leaking, it could ingest air when the pump isn't running and fool the TRAC actuator into running too much, which would lead to fault code 54. Just a thought...here's a scan from the manual that shows the pump and accumulator:
I'd say take it to the dealer or a high-tech brake shop. Bleeding all the air out of all that plumbing is quite a process, according to the manual. Probably a Lexus dealer would be best, those O-rings must not be re-used, in fact if it's wet at the fittings that's all you may need, just O-rings - if you're going to have the fluid flushed & changed, get the leak fixed at the same time, have them reset the ecu and see if that solves your problems...
