easiest way to route intercooling piping for single sc300
Finally going single so a question that came up when i was looking at my engine bay is how am i going to route my intercooling piping to my single turbo? Maybe cut a hole into the frame?
1JZ Single SC400
I don't understand why anyone who would want to cut a hole in the engine bay. Run the piping under the passenger side headlight. If you choose to run a 3 inch piping, then you must remove a tab under the headlight. Very easy, just pry it off. You run it the way you see fit, but I would not cut a hole in the bay compartment. There are many configurations to choose, before doing this.
Check out my build thread.
1JZ Single SC400
Let me know if you have any further questions. The "Build Thread" section has many different style and configurations on running it, even on people choosing the best location on their BOV. Either side is find, if no boost leak is found.
kylesc400
SC- 1st Gen (1992-2000)
16
03-14-03 04:56 PM
