LED swap questions
#31
Old Man, I've collected these:
1992 Lexus SC400 Car Light Bulb Size Diagram
Low Beam Headlamp Light Bulb Size: 9006 or 9006 HID Upgrade Kit
High Beam Headlamp Light Bulb Size: 9005 or 9005 HID Upgrade Kit
Parking Light Bulb Size: 168
Front Turn Signal Light Bulb Size: 1157A
Rear Turn Signal Light Bulb Size: 1156
Tail Light Bulb Size: 1157
Stop Light Bulb Size: 1157
High Mount Stop Light Bulb Size: 1156
License Plate Light Bulb Size: 168
Back Up Light Bulb Size: 1156
Front Side Marker Light Bulb Size: 168
Rear Side Marker Light Bulb Size: 168
Glove Box Light Bulb Size: 74
Map Light Bulb Size: 2040
Dome Light Bulb Size: 194
Trunk/Cargo Area Light Bulb Size: 194
Instrument-General Light Bulb Size: 194
Interior lights and bulb type numbers:
Dome: 31mm festoon / DE3175 / Polarg M16
Map: BA9 / 1895 / Miniature bayonet / Polarg M17
Doors: 194 / 168 / Polarg M4
Footwell: 74
Ignition: 74
Visors/vanity: 31mm "vanity type" / Polarg M24 may fit
Glovebox: 74
Trunk: 194 / 168 / Polarg M4
I'd pull out your old lights and compare - the festoon lights come in a few different lengths so make sure you order the right one.
I put LED's in my Tacoma and they really helped - a ton. For my main cabin light (it's an extended cab), I got one of those festoon bulbs that's connected to a 2"X2" circuit board packed full of LED's. It really lights up the place.
I opted not to put LED's into my SC's map lights because I don't like their angle - instead of pointing straight down, they're pointed back a little so they are partially shining into my eyes. My wife sometimes turns them on while we're driving and forgets to turn them off. I know I'd be blinded if I put LED's in there so that's why I left the old ones in...
RE: the flasher, check out the first page of this thread - there's a link for an entirely different flasher so you may want to check that out. I haven't done mine yet so I'm not sure who's right, how many pins on it, or maybe you pulled out the wrong one ?
Footwell: 74
Ignition: 74
Glovebox: 74
#38
Hey guys, we have all of these LED's in stock and ready to ship.
The 168's are $1.99
http://www.taninautoelectronix.com/T...p/t10_5led.htm
The 74's are $1.99
http://www.taninautoelectronix.com/T...-p/t5_3led.htm
The festoons are $2.99-$9.99 depending on brightness
http://www.taninautoelectronix.com/F...estoon_led.htm
We also have the 1156 and 1157 LEDs
http://www.taninautoelectronix.com/1...6_tall_led.htm
http://www.taninautoelectronix.com/1...p/1157_led.htm
Let us know if we can assist with anything related to LED lighting and support a vendor!
The 168's are $1.99
The 74's are $1.99
__________________
TANIN AUTO ELECTRONIX
262-456-4147
contact@taninauto.com
262-456-4147
#39
so installed the flasher... FAIL. when i choose the left turn signal both the signals flash, and when i choose the right, nothing happens at all. hazards work, they flash at the right rate though. the pins are identical to the stock one. something different about the flasher then i guess.
#45
