Door panel Screw.
There are 8 in total for each door panel. Two long ones inside the door under the armrest. Two small fat ones hidden with caps near the door hinge. Three below at the bottom of the door panel. And one above the door handle, you just have to remove the cap. Unfortunately I do not know the sizes, the best bet would take the ones from your current door panel and go to a local hardware store like Ace or True Value and they can give you matching screws. Sorry I don't know the exact sizes. At the bottom(Numbers 99999) they list screws but it's hard to tell exactly which ones are which...
http://lexus.sewellparts.com/oem-cat...C400-1996.html
Thankss 1jzpwrd. But yea the only problem is trying to figure out the specifics of it. Nobody at the store knew. Anybody out there wanna lend a hand here. It'll be much apreciated. Just boght 2 great and clean black panels from a fellow sc member here for Lexi but with no screws they are just collecting dust in my room.
Forum Administrator
![](https://www.clublexus.com/forums/images/ranks/rank-admin2.gif)
If you can't find extras from anyone on the forum, take the screws you need matched to a Fastenal store.
https://www.fastenal.com/web/locations
I have plenty of extra screws. Depending on part of CA you are in, you can just go through them and have them for free. (I am in Gardena and work in Westminster)
