Door Pillar Restoration
I've tried painting it, properly too, by using stripsol on the old paint, then scuffing the stainless steel underneath with a rough sand paper, so the primer would stick well, then a good black glossy paint, and clear coat. Didn't really last that long. It's been roughly 3 years and now it is starting to peel off. If you can't get a pro with good equipment to paint it, I strongly recommend just getting it covered with vinyl sticker the same kind they use to cover up entire cars. I think you have a better chance with that lasting longer. Good luck.
