SC- 1st Gen (1992-2000)
Quick question - Butterfly cupholder
Old 02-28-14, 06:45 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
Default Quick question - Butterfly cupholder
Just a quickie I needa know. Wondering since the butterfly cupholder didn't come with the 92 SC's, if they will still clip right in with no trouble? I got one and tried sliding it in and it didn't want to go in all the way. Is it incompatible?
TIA
Old 02-28-14, 08:01 PM
k7q
k7q's Avatar
i think you need to cut squares on the panel so it would clip on.
Old 02-28-14, 08:09 PM
Duck05
Duck05's Avatar
I tried searching for it but did not find the thread on this item. A few folks have installed the holder in a '92 and as I recall it requires something to hold the tab to the back wall of the slot.... I will keep looking and if I find it will add the link....
Old 02-28-14, 08:13 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
If you ever find it, I'd be interested!
Old 02-28-14, 08:21 PM
962jzsc415
962jzsc415's Avatar
You have to remove the center console and look at the back of the cup slot and remove the backing. Then snap the cup holder in place. DONE!
Old 02-28-14, 08:23 PM
SC400slide
In Recovery Mode
SC400slide's Avatar
So that plastic thing in the way can be removed...good! The cupholder is perfect fo an iPhone.
Old 02-28-14, 08:25 PM
962jzsc415
962jzsc415's Avatar
DONE!
Old 02-28-14, 11:31 PM
Kris9884
Kris9884's Avatar
Yep exactly, have to punch out the backing, its practically meant for it but Lexus just didn't get to it or something?
Old 03-01-14, 09:47 AM
grm405
grm405's Avatar
Well, there is another way. Cut off the mounting tabs on the cup holder (mine had one broken off anyway), drill 2 holes in it and mount it to the plastic panel in the mounting recess with a couple of sheet metal screws (black if possible). You also want to sand/file off the little ridges on the back of the cupholder so that it goes as as far into the recess as possible. That is the way I did it and it works fine.
Gerry
Attached Thumbnails Quick question - Butterfly cupholder-dscf0961.jpg   Quick question - Butterfly cupholder-dscf0962.jpg
Old 03-01-14, 10:03 AM
SC400slide
In Recovery Mode
SC400slide's Avatar
Perfect! I might try this!
Old 03-01-14, 11:52 AM
Shrugy
Shrugy's Avatar
I'm with ya on this SC400slide. I just bought a cup holder, and I think the best approach is to remove the backing by taking out the center dashboard. I plan to do this when I have an aftermarket head unit to install.
If you end up doing this, please take MANY pictures of your steps in the process so I can check them out if and when I do this myself.
92' SC FTW
Old 03-01-14, 11:55 AM
Duck05
Duck05's Avatar
Here is the link that I recall and grm405 posted there before with his option...
https://www.clublexus.com/forums/sc-...-question.html
Old 03-01-14, 07:06 PM
xiaolong
xiaolong's Avatar
dude, the console pops out just enough to get your hands back there to squeeze the tabs and pop out that filler plastic. Don't drill your car. The tabs are there, you just have to pop out the plastic cover that's in the way
Old 03-06-14, 08:33 AM
FD3etty
FD3etty's Avatar
Where do you find a cup holder for sale!????!!??!!
Old 03-06-14, 08:34 AM
SC400slide
In Recovery Mode
SC400slide's Avatar
SC300/400 Classifieds here on the forum.
Quick Reply: Quick question - Butterfly cupholder
