tire size thread opinions
Hey all, so I'm going for a really aggressive minimal negative camber stance. The wheels I currently have on my rear are 19x11 +0
Fronts are 19x9.5+11
So I want really wide tires. Would a 325, 30?be to much on an 11 or would a 305 be more acceptable. I'm not going for the stretched look on this car.
And what front tire size would go flush with the the rim a 245, 30? Or should I go staggered on height(aspect ratio) like the supra stock tires, like a 35 front 30 rear...
I run a 19x11.5 on my rear with a 315/25 tire. I've run 295/30 I think (whatever the widest ta kdw 2 is) and it was fine. The 315/25 seems about perfect. A 325/30 is going to be a big diameter tire. It wouldn't fit on my car I don't think and my fenders are pulled/rolled and I'm not slammed. With yours sticking out past fender hope you got a lift kit. Lol
Speaking strictly from a width of tire on that rim you'll be good anywhere from 295 to 325 depending on brand.
Forgot to add, fronts i run 265/30 so diameter is near the same, about .1" off. I like my wheels same diameter so I'd go that route but up to you. Look online at a tire size calculator, the one on a miata site is awesome to compare measurements on different tires in terms that make sense.
There's no way I'm putting a 245 on the rear. I would have used Honda wheels if i wanted that width. Even my stock supra tires are wider than that
i ended up grabbing bridgestone potenza so4 pole positions 255/35/19 front and a 305/30/19 it looks really good i think ill post some pics once i roll and pull and get my coils on
i don't think you understand how badly those rear wheels are not going to fit like you expect them to... the fronts will be fine with a pull... not so much those rears, tires are going to be an issue
from another thread
another car:
he had to run 245 on a 19x11 +0.......... whew
https://www.clublexus.com/forums/sc-...ster-reps.html
![](http://i360.photobucket.com/albums/oo41/chnkylao/DSC_0087_zps1ab733ea.jpg)
