climate control stopped working
i pulled my motor and fixed it up and dropped it back in, went to go burp the coolant system and my climate control isnt working so i cant turn on the heater. the climate control isnt getting any power at all. checked all the fuses and theyre fine. is there a connector somewhere other than in the car that sends power to climate control? im a little dumbfounded right now
i dont have a spare climate control so i cant verify if its my actual unit that crapped out on me, but i dont think its the actual climate control. it was working just fine before i pulled it. i checked the fuses and theyre fine. so where else should i look?
thats kinda what im asking, what wires to check. i dont knw which one is the power wire. i did probe one red wire on the middle connector and it said 12 volts when the car was turned to on
heres the link for the schematic.
http://www.files.com/shared/5324b10b...hop_Manual.pdf
the wire i test was indeed the power wire and the connector is getting power. no a coin didnt fall in the the cigarette lighter. and the fuse is good too. which leads me to this: 1) either the unit just out of nowhere broke or b) its not being grounded properly?
SCreal help me understand this, on connector a14-6 (ecu power) theres supposed to be 12 volts. i have 12 volts there. is there also supposed to be 12 volts on a14-15 (acc power source)? i have only .04 volts right there
