Car wont start again
well fellas, after numerous attempts to start my baby, no luck. I finally received the manuals from sewell and will attempt to troubleshoot. My ride only acts up when it is cold outside, but the second it warms up, no problem. I had a few would mechanics tell me its not the starter but it sounds as if my engine isnt getting fuel. So i figured it must be the cold start injector. My battery has been tested, my alternator is brand new. So if anyone has any other suggestions let me know.
Bluegr*** Performance
Try the battery - make sure contacts are clean.
Check ground connections - as many as you can find.
Check fuses - the starter relay.
Check your fuel filter, distributor rotor, wires, plugs.
Then go to your fuel pump ecu - and troubleshoot from there. If you want to do all this yourself you're going to need factory manuals unless you know the car well.
check this thread on fuel ecu - page 2
Also, as pcmw would say -
the search button is your friend.
