Can't find Tach Wire, Please help!
Hey guys,
I'm in the middle(actually towards teh end) of my alarm/remote start/turbo timer install on my 93 sc300 and we can't find the tach wire for the car. There are a few that we have narrowed it down to but the instructions aren't too great so we are a little lost now. Does anyone know which wire exactly it is? Also teh oil pressure wire..... There are too many wires in the dash area so we gave up on looking in there but does anyone know which wires exactly the tach and oil pressure are under the steering column?
Your help is greatly appreceated
racing fan,
I went to the engine bay to tap the tach wire. It is relatively simple to locate. There is a diagnostic plug with a simple black wire. If you meter it you can see it vary and it will be obvious.
MW
MW
Not quite behind the strut tower, but it may be in a SC400 or different years.
It is just the standard Diagnostic plug. Cut off the loom and test the black wire.
MW
MW
Originally posted by pcmw
racing fan,
MW
racing fan,
MW
EDIT I guess you were talking abour the one in front of the intake manifold. Is it the only black wire in there? Where did you open the loom at? Thanks alot!!
Ok, its opened up. Is it the black/red, black/yellow, or black/silver dots?
Can you see the PICTURE.... You can see the electrical tape re-sealing the loom about 1" down the section.
MW
MW
Thanks again!!
Alright. I'll give it a shot. One last Q-hopefully
Where di you run the wire through the firewall? Drill a hole on the drivers side? I'm trying to avoid running it on the passenger side and back around to the drivers side as the current wire isn't long enough.
Look to the right of the brake master cylinder and you will see a 1" grommet. I have run everything from alarm wires to 4ga amplifier power thru there.
Best of luck. However, this is an easy deal. Do not make it more difficult that it needs to be. Take your time, plan it out. Measure three times, cut twice, and screw up once.
MW
MW
MW
MW
I just ran it through the nipple.
Everyhting is working now(remote start, turbo timer, door LOCKS) except for teh door unlock. Its pretty weird because it was working this morning before we had some of the other stuff working. When you hit the button to unlock the brain just clicks but we can't find any loose wires or anything. Any ideas?
Thanks alot for all the help!!!!!!!!I owe ya one
UPDATE The unlock works now. The clamp became a little loose off of it. Needless to say we fixed it so that won't be happening again
Time to mount the proximity sensor.. Do you know the best place to put it? I don't want it too out in the open as its a black box and rather ugly...
Oh man....
You need to plumb this with the factory alarm feature of your alarm. This will initiate and the re-lock the signal and therefore disable the factory alarm if you have one. Wierd deal... when I autostart to leave my car running when I want to jump out at them ATM or anything I use this but have to wait for the second lock sequence to release.
MW
MW
