SC- 1st Gen (1992-2000)
car won't start, didn't have time to search
Old 02-18-03 | 12:01 AM
voeltz's Avatar
voeltz
Default car won't start, didn't have time to search
Ok....so there I was...nice warm day...then a new snow fall. Basically there was maybe a half inch of fresh snow over ice, I was taking a 55 degree right hand turn (at about 23 mph), my car spun around and my driver side door hit a pole then my *** end hit the curb leaving my car set facing the right way in the street after it stopped, only it died and will not run.... given my drivers door has a nice dent and my mirror is gone, but why won't it start. I'm thinking that because of the EFI, when my car hit the pole it set of a sensor to shut down my car, leaving fuel in the combustion chamber causing it to flood...I gave it a half hour and it still won't start. I'm running a Jacob's electronics ignition w/NGK plugs, this shouldn't have anything to do with it, right? I checked all of the connections and they're still intact. So I guess i'll wait for morning (now 1am central) and try starting it again in hopes that it just got flooded. i'm lost...help me now, and thank god I have full coverage.
Old 02-18-03 | 04:54 AM
GA400's Avatar
GA400
CL Folding 100000
Question Sorry to hear of your trouble...
That sucks, dude. Have you tried disconnecting the battery completely (negative side is safest), allowing it to remain unpowered for several minutes, then reconnecting? If it is a sensor, this will force all systems to go through a reset and self check.
Worth a try in my opinion.
Good Luck
GA400
Old 02-18-03 | 05:02 AM
London Bill's Avatar
London Bill
An impact on your drivers side could have taken out the fuel pump ECU inside the rear quarter panel, try the fuel ECU diag test. SoarerTT You will find details in Electrical.
The impact could have dislodged the crank sensor?
Any errors on the engine diagnostics?
Old 02-18-03 | 09:01 AM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
most vehicles have as fuel cutoff switch you should just be able to press and it restore fuel flow. majority of cars have them to keep gas from feeding to the engine incase you are knocked unconcious.
now where that may be located on an sc.....well........
Old 02-18-03 | 09:41 AM
voeltz's Avatar
voeltz
I'll check for error codes and blow fuses for the EFI. I have no Idea where the fuel cut off switch would be for our cars, I imagine its done by the computer and probably needs reset. THanks for the help guys, I appreciate it.
Old 02-18-03 | 09:42 AM
voeltz's Avatar
voeltz
OH yeah forgot...there was a really funny smell in my car after it happened...like, sulfur?????????? you got me...somebody told me thats the smell of rear diff. fluid, but why in the hell would the diff have anything to do with it?
Old 02-18-03 | 10:42 AM
V8RWDHP's Avatar
V8RWDHP
Were you wearing a seat belt? I'm not positive about our sc's, but some seat belts have a small cap like that in a toy cap gun that blows out on impact to retract the belt. It's possible that was the smell. If so, the seat belt unit needs to be replaced for it to be effective again.
Old 02-18-03 | 10:52 AM
voeltz's Avatar
voeltz
yeah I had my seatbelt on...and it did smell like a cap gun. so what exactly does this do then??? I know the seat belts lock when they're pulled quickly, but something blowing up in there??? strange.
Old 02-18-03 | 11:14 AM
London Bill
Seat belt pre-tensioner - a small charge is used to take slack out of the seat belt on impact, prior to the belt arresting the occupants motion, stops the snapping action that happens if you fly forward on impact when the belt is loose fitting.
Old 02-18-03 | 11:32 AM
awj's Avatar
awj
Bluegr*** Performance
Damn voeltz,
I'm really sorry to hear about that. It's hard to say exactly what the problem is now. Try all the previous recommendations. Don't forget about the starter itself. But it is all speculation. Is the damage extensive? Will you keep it? I hope all works out for the best.
Old 02-18-03 | 11:41 AM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
what are the chances of you getting a few shots of the damage so we get a better idea of the impact and what it could have affected?
Old 02-18-03 | 12:14 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
when i wrecked my truck a few years back, i found myself wishing santa's elves knew body work.
Old 02-18-03 | 12:23 PM
voeltz's Avatar
voeltz
well I just went back to where it's parked and tried to start it...I disconnected the battery for about a minute or two, I check the EFI fuse, etc...I turned on the ignition and I can hear the fuel pump working. I looked at the damage, not too bad, will need a new door skin. I pulled a little chuck of wood out of it from the telephone pole, and it also pushed in the door panel on the inside, i'll probably need a new one of those too. I'll try to take some pics today...
Old 02-18-03 | 12:25 PM
voeltz's Avatar
voeltz
oh yeah, AWJ, the car turns over fine...everything sounds really good. I'm going to bypass the aftermarket ignition and see if that helps. Its failed me before, maybe thats all it is again.
Old 02-18-03 | 07:39 PM
voeltz's Avatar
voeltz
OK i got my car started, I just bypassed the Jacob's ignition... ALl i have to say is never ever buy a Jacob's Electronics ignition system. It's been nothing but troubles. And they're way overpriced for the little amounts of performance they give. But I do have my camera now and i'll takes pics and post them tomorrow. thanks for the help again guys!
kenEs350
ES - 5th Gen (2007-2012)
02-26-15 04:27 PM
winner155
24
02-15-12 06:13 PM
CDN_Drew
02-09-12 07:55 AM
Im2gq4u
Performance & Maintenance
09-09-08 05:14 PM
TTCUPS
03-02-05 03:48 PM
