I been reading up on this and it seems like some say it will work and some say it wont
I have a 95 2jzgte rear sump supra swap ready to go in my 93 sc300, will the long motor mounts and brackets on my swap be fine? or do i need to put the original sc300 brackets and mounts back on?
suppose that depends, if you have the Long Engine Mounts or the short ones...
First picture is what My engine mounts are/look like, and the second picture is the corresponding Supra Mounts.
(albeit the TRD ones but the non trd ones looks almost identical.. and these are interchangeable - however as I was advised by a lexus tech a couple years ago, there is a reason the SC mounts have a shield on them - I cant recall exactly what the reason was, but it was more indepth than just being a heat shield.. meh
The rubber formulation is supposed to be slightly stiffer in the Supra mounts vs the SC mounts. I also recall reading that 97-98 Supra mounts (or brackets?) are the best option. Can anyone shed light on that?
