Getting car on 4 jack stands
This might be a silly question, but what is the proper procedure for getting the car up on all 4 jack stands. I'm aware of the front jacking point as I've used it a million times, but is it safe to lift the rear of the car while the front is sitting on jack stands? Do both sides need to be done at the same time to keep the car level? Or can I lift the rear while the front is in the air without fearing that the car will just slide backwards and crush me? (Yes I really have convinced myself that this will happen).
I know being lowered just compounds this problem but I've already got a set of 2x4 ramps I can use to get each wheel higher off the ground so it can clear my jack, I'm just curious because I want to do motor and tranny mounts in the next month or so and I'd like to do them at the same time as I do the diff bushings, and maybe do SS brake lines on the same jack since all but the diff. bushings will be a simple and quick job once the car is up.
Anyways I'd like to get comfortable getting all 4 corners of the car raised, especially since I already have 2 jacks and 4 jack stands but never used them all at the same time, so if anyone has any input I'd love to hear it.
I'm always curious what all the safe jacking points are. I usually use the corner points from the owner's manual instructions, but mechanics seem to prefer subframe and control arm points. That might open up some options for you to jack from the center of the car to keep it level instead of doing one corner at a time.
If you can figure out the ground clearance, you could also use a set of ramps to get one end up in the air and stable, then jack the other end up from a center point.
I use the factory jack points front and rear. When I put my car on all 4's, I generally do the front first, and then jack the drivers side rear and slip the stand under. I have never had an issue switching sides with only 3 jacks under the car while moving to the passenger side.
I have however had issues using the diff and it sliding. I have had my car up on all 4's many times going front to rear, just make sure your front jacks are sitting level.
Also keep in mind once the front is up, when you jack up the rear drivers side, it will raise the entire back of the car. So if you have 2 sets of hands, you can set the rear jack under both sides at the same time. Had my other pair of jack stands not been stolen, I would make a quick video.
yeah that is a good point, the suspension is tight that happens often. also when lifting all 4 corners there is a lot of weight on the jacks and I find that the lift points on the pinch welds have a tendancy to crush when lifting from all 4 corners. so be carefull where you place the jacks you don't want them going through your rocker panel if you miss the strong spot on the pinch weld. this is why mechanics often use the arms or the subframes or rear diff to lift, because you won't crush the pinch welds that way and some people get upset when that happens. you can cover the mistakes with a side skirt but for those that don't have them you may want to be more careful.
all my corners are crushed, but they were already when i got the car. so now i just stuff the jack and stands in the flat part where the pinch welds used to be, but now it's just flat and nice and thick there lol.
I have always used sub frames and diff to jack the car. Also I like to use the subframe for stands as well, just had my sc on stands for a month and used front/rear subframes. And all my pinch welds are in perfect shape.
Yeah lol I always put my jackstands on the subframe. Whenever I get around to Supra LCA's though I may have to put the jack stands on the corner and prepare for a pinch weld or two to crush. So far all of my pinch welds are pristine. I guess the PO's all used the subframe as well or had shops do all of their work. Who knows, but I honestly don't care too much since my skirts cover them up.
