Damage to Drivers Side Door, cant open
Just picked up another SC400, a 92, mechanically seems pretty good but needs a bit of work
I want to replace the door as its stuck closed, I think because its locked and its stuck locked and I cant unlock it, so maybe the lock arm is stuck due to the damage?
![Damage to Drivers Side Door, cant open-ab4cc2z.jpg](https://www.clublexus.com/forums/attachments/sc-1st-gen-1992-2000/495057d1683162958t-damage-to-drivers-side-door-cant-open-ab4cc2z.jpg)
would a Slim Jim be able to work in this case?
I was trying to pry it while unlocking it and trying the handle.
something would break, I suspect it wouldn't be the door catch?
you will just end up doing more damage to the chassis if you pry it off while its locked and not even able to open.
sacrifice the door card already. when you loose the outside or inside its a mad rush to get ir fixed before the other one goes because its easy to fix when you can open the door. when you can't open the door inside and out, the door panel has to be sacrificed more or less as some of the screws are under the door. you could try undoing most of them on the panel and hulking it off and basically tearing the bottom ones out you can't reach, but I haven't tried or recommended that before. someone said they could get the door panel off with the door closed but the general consensus is its very very difficult if not impossible without cutting it open.
if you break off the door latch which is attacthed to the A pillar on the car body (not the door), you are going to bend out that section and it will require more body work, and once that area is weakened and repaired it may keep breaking in the future, so I would say sacrifice the $80 lower panel already and get the door open, remove it and replace it with a working non bashed in door. I mean you have to find another door anyways it will have some kind of panel on it hopefully. If you have the beginnings of the sagging door hinge issues, then look into doing that also while in there as you will have to realign the new door anyways.
I can tell you there is no way you will get that door open now without physically reaching the door lock actuator which is in the middle of the door right where the door meets the car or hope that the door release rod is still mostly in tact. a slimjim might work but if the door opening metal rod is broken bad enough you may not be able to pull it without getting deep in there.
this guy in the last post says he was able to remove the window trim and reach the door rod. you can maybe give that a try. I would try that and maybe the slimjim route first and hope there is enough of the rod left to get it open, its not impossible.
https://www.clublexus.com/forums/sc-...outside-2.html
I have heard of people destroying the door panel as said above also, and some that try and get it off without destroying it but not sure how effective that is (must be houdini I break something every time I take it off and thats with the door open).
normally that is the main way you can get to the actuator and open it when it does not open from either handle, sacrificing the panel, but try a few other ways like remove the window stripping and get more room to look down there for whatever part of the handle remains.
Do not break the window its much more expensive and might not even work so well.
now if your accident is physically keeping it from opening, thats another problem, but looks like once you unlock it and pull up on the release rod you should be able to kick that thing out.
also if you are replacing the door, you could use a grinder and cut a square into it from the outside till you can reach the actuator. sort of like destroying the trim but in this case destroying the door, cause well, your door is already destroyed more or less. a hole saw might do it too but you may shoot right through the door and hit the panel anyways on the other side.
Glass is already gone in both doors, I need to replace these things ASAP as its very inconvenient lol
I just need to find a way to destroy the door card so I can put it back together temporarily until I can get that ever sought after Black interior.
yeah do a search on door wont open inside outside you will see all the threads people have suggested different things. destroying the door card is a sure fix I mean that is what you take off to replace the broken parts. you only need to break the bottom part I think.
Update to this:
I had to rip out the door panel, and pound out the dent and the support, as it was jammed INTO the lock making it impossible to open. I kept hitting it with a 2x4 and a hammer till it inched its way out of the way and the lock would disengage. and the door opened.
I am hoping to salvage the lock mechanism since the door I got has a messed up one (arms are all ripped off)
or possible I could combine the two?
(I am prolly going to have to buy a new one)
