SC- 1st Gen (1992-2000)
Which coolant??
Old 10-19-14, 11:47 PM
Aron9000
Aron9000's Avatar
Default Which coolant??
Car is a 1992 SC300, it has the toyota red stuff in it now. Last change I assume was in 2010 at 55k miles, when they did the timing belt. Car now has 82k on it.
So do I just bite the gag ball, take it up the well you know, and pay $35-50 for red coolant from the dealer??
Or is there an alternative I can use? I've heard that you should never mix coolant types, ie traditonal green with toyota red, and that red GM dexcool is the devil. Apparently dexcool has something in it that eats at the rubber gasket seals.
Old 10-19-14, 11:58 PM
Justin2JZ
Justin2JZ's Avatar
Always use OEM coolant. You can cause corrosion in the internal components if he wrong coolant is put in. Join sewell lexus online and enter your CL username youll get a discount. $21 online.
http://lexus.sewellparts.com/accesso...1999/4369.html
Old 10-20-14, 02:03 AM
eknine9
eknine9's Avatar
Toyota Red is preferable.
Green coolant is completely fine in the iron block of the SC300, but there are concerns for how it interacts with the aluminum block of the SC400, it's honestly probably fine on the SC400 too but whatever, I dont need to know since I have a 300.
Don't use orange Dexcool in anything... ever.
Old 10-20-14, 04:35 PM
KahnBB6
KahnBB6's Avatar
Received 1,247 Likes on 868 Posts
^^ This is true. The iron JZ block is more tolerant of coolant types than the aluminum UZ block. All cylinder heads are aluminum, however. I have used Toyota "pink" 50/50 pre-mixed coolant ever since I installed a Koyo radiator.
Old 10-20-14, 09:43 PM
CatManD3W
CatManD3W's Avatar
I only use Red Toyota Coolant in both my Tacoma and SC300.......I purchased mine from Toyota dealership for $28....You only need one....
Dont cheap out on the cooling system of your ride....
The proper way to replace the coolant in the system....is to drain the old coolant out of system.....Fill up the system with distilled water and drain....Then 1 Gallon of Toyota Red to 2 Gallons of distilled water....
Old 10-21-14, 05:17 PM
Aron9000
Aron9000's Avatar
^ Don't know how you'd fit that much liquid into the cooling system. Manual says the capacity is 9 quarts, 2.25 Gallons. Or 4.5 quarts coolant, 4.5 quarts water, which I've always been told you mix coolant 50/50 with water.
BTW, will coolant go bad just sitting on my shelf until I do this 3 years down the road again?
Old 10-21-14, 05:49 PM
CatManD3W
CatManD3W's Avatar
It will not fit all that liquid you are right.....you do 1 gallon of Toyota Red and 1 Gallon of Distilled water..i.e 50/50......but your system will not be completey full.....The extra gallon of distilled water is to top it off....
Old 10-21-14, 09:51 PM
Ramblerman
Ramblerman's Avatar
As long as the coolant is safe for all aluminum engines (it will say on the jug) it should be ok, but dealer recommended is always safest bet.
Old 10-22-14, 09:13 AM
turbodremz
turbodremz's Avatar
Traditional Prestone green for me for the last 16 years I have owned cars. Never trusted the pink or red stuff, especially the GM crap that GM admits to it eating through synthetic and paper gaskets. Not sure about the Toyota stuff, never looked at it.
Prestone undiluted, distilled water, and either Water-Wetter or Royal Ice additive.
Old 10-22-14, 11:14 AM
Ali SC3
Ali SC3's Avatar
Toyota red on all my toyota's that I care about. 1 gallon of the non-diluted stuff, then top it off with your favorite garden hose or distilled water depends how picky you are.
Don't get toyota pink unless you like paying the same for half the coolant and a half gallon of distilled water.
I have used the green prestone before on my toyota pickup and it works fine and is definitely more cost effective, wouldn't waste toyota red there it would have just blown a headgasket or something in 3k miles anyways to spite me, but I don't drain the SC that often so it gets the good stuff.
generally if I get a toyota with the red stuff in it I will continue it, but if someone switched it to the green usually green is what it will get.
Gs350Lola
10-09-23 04:05 PM
voleduy
IS - 1st Gen (2001-2005)
29
09-12-10 09:05 PM
Ls4hundred
23
08-24-09 11:24 AM
arodriguez
Maintenance
01-09-09 03:52 PM
btanchors
Maintenance
06-16-05 03:16 PM
Quick Reply: Which coolant??
