SC- 1st Gen (1992-2000)
ABS WA & WB diagnostic pins?
Old 10-25-14 | 10:54 AM
t2d2's Avatar
t2d2
Default ABS WA & WB diagnostic pins?
I was looking at this post and noticed that little jumper on the lower right of the diagnostics box. When I had my intake manifold off a couple weeks ago, I was cleaning up various stuff that had fallen down there over the years and found a little pin jumper thingie under the diagnostics box that fit some of the terminals perfectly, so I set it aside in my testing kit in case it's useful in the future.
But seeing that photo, I immediately recognized the mystery jumper. Sure enough, it fits those two terminals. I had to look up what WA and WB signify, since I've never done anything on the car requiring attention to those. I found that they're for the ABS (anti-lock braking) system, but couldn't find much more than that. WA = ABS ECU, WB = ABS relay.
https://www.clublexus.com/forums/ls4...ml#post8223544
https://www.clublexus.com/forums/rx-...ml#post6556359
My guess is, the jumper is supposed to be in place otherwise ABS is deactivated? Wouldn't one expect to get a CEL in that case? Actually, scratch that, I see the ABS codes are separate from the engine codes. That second link above (RX300 thread) sounds like it's just a matter of jumpering the Tc and E1 pins (as opposed to E1 and TE1 for engine CELs) with the WA-WB jumper removed.
I'm curious if the jumper was removed because something in the ABS system isn't working or if someone dropped it down there and couldn't recover it...
Old 10-25-14 | 11:47 AM
t2d2's Avatar
t2d2
The ABS and Cruise lights blink constantly with Tc/E1 jumpered and the WA-WB jumper removed. Constant blinking on engine CEL means no codes stored, so that's encouraging assuming I followed the right procedure.
Anyone know whether having that WA-WB jumper removed disables the ABS system? I've yet to do any uber emergency breaking that would tell me if it's been working or not.
Old 10-25-14 | 03:45 PM
t2d2's Avatar
t2d2
Found this:
http://www.justanswer.com/lexus/3q85...97-causes.html
You can retrieve the ABS diagnostic codes by installing a jumper wire in terminals TC and E1 in the diagnostic check connector box DLC1 under the hood. Inside the lid of this rectangular check connector box will have the location identification of the pin numbers. Once the jumper wires installed then you need to remove the jumper pin that is in the corner of the same diagnostic check connector box be careful you do not lose this jumper pin. Then turn the ignition key on and monitor the ABS light it will flash a series of codes.
That would seem to confirm that the WA-WB jumper is normally in place and is only removed to retrieve ABS codes.
ninja757
RX - 1st Gen (1999-2003)
04-03-16 09:07 AM
jayr1
07-07-14 06:00 AM
RocketGuy3
Suspension and Brakes
08-12-08 10:22 PM
faithless
06-20-08 02:36 AM
