How to removed shift knob?
How to removed shift ****?
Trying to repair ac light and install secondary cup holder for 92 sc400. How do you removed shiftter ****?
Any suggestion on ac light removal or light bulbs is appreciated.
thanks,
Dan
thanks,
Dan
Keeper of the light
the base under the **** slides downward and reveals two screws. if you need help when in the ac unit send me a p.m. and i'll guide you through.
note: unless you use a certain bulb the replacement lights won't be as bright. the factory lexus bulbs and the denso's are not the right one's. I currently run a bulb set that emits a glow on the ac unit, it is so bright.
Good luck!
Good luck!
Re: How to removed shift ****?
Dan
Dan
maynanator
SC- 1st Gen (1992-2000)
19
03-30-10 06:24 AM
